Is it possible to name certain dimensions for configurations rather than the default?
RhettRobinson
Member Posts: 172 ✭✭✭
Examples of Names: Overall Length, Overall Width, Arm Length, Arm Width, Gear Width
I understand that you can name the inputs when you "Add configuration input" or edit the top level name (in my pictured example, "Configuration"), but in this instance I need each configured part to have all of the values predetermined rather than having to select each combination. It would be great to know what the values correspond to as actual parts.
tim_hess
Member Posts: 46 ✭✭
I know it would be an extra step, but could you drive those dimensions with variables and then configure the variables? Wouldn't that show the variable names in the table?1
https://forum.onshape.com/discussion/19223/names-for-configured-dimensions
https://forum.onshape.com/discussion/18716/sketch-relations-and-dimensions-tables/p1?new=1
