Onshape Featurescript Query - return XYZ coordinates of a mouseclicked point on a part
joshua_lee840joshua_lee840 Member Posts: 6 ✭✭
edited November 2022 in Community Support
Hello Onshape:
I want to make a featurescript that queries for the user to click a point on a surface or edge, then returns the XYZ coordinates of the spot that was clicked. This would greatly simplify a lot of work for certain kinds of freehand work that I have been doing recently. I have attached an image to serve as an example.
I noticed that right-clicking the model and choosing [Select Other] in the dropdown menu causes a yellow symbol to hover over my surface, which is very close to what I want. Can you advise me on how to access this XYZ-coordinate?
My end goal is to create mate connectors at selected points with the Z axis sticking out normal to the surface. Some of the objects I work with have organic shapes that require a lot of trial and error to get the right mate locations.
Sincerely,
Joshua Lee
  • MichaelPascoeMichaelPascoe Member Posts: 2,452 PRO
    Check out the functionality of Freeform Spline by @Evan_Reese. It has some very nice manipulators that are doing something similar to what you need. With this technique, you could click the face, then drag the manipulator to the point you want.
    Also try Face curves by Evan as well.
  • joshua_lee840joshua_lee840 Member Posts: 6 ✭✭
    Thanks! I will take a look.
  • EvanReeseEvanReese Member, Mentor Posts: 2,471 ✭✭✭✭✭
    mine uses evDistance to find the closes point on the target object and snap to it. I've really wanted the thing you're describing though! I think this is how match connections in Loft should work anyway when matching to an edge. It just defaults them all to a parameter of 0.5, which is often in a nonsense spot, or makes points overlap when referencing the same edge twice and therefore makes it tough to drag where you want.
