Onshape workspace background color flickers between white and black.
ed_beickman
Member Posts: 5 EDU
I have students using onshape in class on their chromebooks, running Chrome version 107.0.5304.92, . They have started experiencing their workspace back ground change to black and then back to white. This could be dependent on them just moving their mouse around on the screen while modeling.
I have some students whose chromebooks are not having this issue, they are running Chrome version 106.0.5249.112, 105.0.5195.134. I have Chrome version 107.0.5304.88 running on my windows laptop and don't see this happening.
I know in prior posts (around 2020), there was an issue with a chrome update. Is this something similar? Is there a setting change we can make in Chrome?
1
The black background is often caused by a Chrome/graphics driver issue, especially on older Chromebooks.
Have you tried going to chrome://flags/ and enabling "Override software rendering list" on the affected devices? This usually fixes the issue. Let us know if it doesn't.
- Go to chrome://settings (chrome://settings/).
- Click the Advanced dropdown on the left side of the window.
- Scroll down to the System section and ensure the Use hardware acceleration when available checkbox is checked.
- Relaunch Chrome so any changes take effect.
The team is investigating this issue. It seems to be caused by the recent Chrome update. Another workaround if the above does not work is to revert to an older version of Chrome as you suggested.Onshape is such a valuable, generally stable platform to use in the high school classroom. A speedy resolution to this issue by the Onshape team would be greatly appreciated!!
In the meantime, if possible, please use a different browser.
From Brien_McCormick:
This is a Google issue with their patch to Chrome OS and related to your graphics driver. When this happens you might be able to work around it using the following flags in Chrome:
Under
chrome:flagsthis making sure these are set.Override Software enable
Accelerated 2d Canvas enable
Selected HW overlay none
Again, these setting changes fixed the issue on my end for our chromebooks.
