API: Retrieve Variables - Measurements Are Incorrect
Jonathan_Hutchinson
Member Posts: 151 PRO
Using /variables/d/{did}/{wv}/{wvid}/e/{eid}/variables endpoint, the values that are returned for a 'measured' variable are incorrect. I'm not sure if it would require a configuration parameter perhaps, but currently in my document it is defaulting to a random value.
Overriding the calculated value with, say, a plain integer returns me the integer fine and it also updates. So it looks to me like like it's a problem with measurements output.
Also set: 'includeValuesAndReferencedVariables' = 'true'
