When I sweep, there are "lines", how should I get rid of them?
graciano_dinggraciano_ding Member Posts: 2
Just as the title says, when I do "sweep", there are lines (circled in red). Is there a way of getting rid of those lines? Thank you in advance!
    @graciano_ding, select "Shaded without edges" from the view menu.  Also make sure that the line segments and radii in your sweep path are tangent.  There appear to be tangency discontinuities in at least two of your transitions.
  • graciano_dinggraciano_ding Member Posts: 2
    oh yeah there are some discontinuities, I'm gonna fix it. Thank you!
