Performing a search query through the API
shawn_crockershawn_crocker Member, OS Professional Posts: 897 PRO
When I do this, I have been able to get this end point to work.
https://cad.onshape.com/api/v5/documents?nodeId=1&q=_all:P0803&resourceType=filter
This seems to search through all of onshape and not just in my company or "my onshape".  Also, I cannot seem to get any other q parameters to work.  I try using state, or when and I get no items returned.  Is there a better endpoint to be using for this.  I'm also finding that the returned items do not really contain useful information like id's to construct a url or a premade url.  Anyone able to enlighten me on this.  I am not seeing anything about this in the glassworks browser.
  • pmdpmd Member, Developers Posts: 64 PRO
    I looked at some python code I wrote a few years ago using the old (pre-v5) API and it did:
     dest = f"/api/documents?q={searchterm}&filter=7&owner={company_id}"
    The old API Explorer explained that filter=7 meant restrict to company docs but the new glassworks browser does not seem to show this info.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 897 PRO
    I was just supplied this link by @lougallo.  https://cad.onshape.com/glassworks/explorer/#/Document/search.  I'm not sure why I wasn't seeing this before when I was searching through the explorer.  I think I was accidentally assuming I was looking for GET requests.  Looks like parameters can be supplied into the body.
      "documentFilter": 0,
      "foundIn": "ALL",
      "limit": 0,
      "luceneSyntax": true,
      "offset": 0,
      "ownerId": "string",
      "parentId": "string",
      "rawQuery": "string",
      "sortColumn": "string",
      "sortOrder": "string",
      "type": "string",
      "when": "ALL"
    I haven't had time yet to experiment but I am getting strong feelings "ownerId": "string", is where the companies ID is to go.
    I have been experimenting and I have run into a problem.  Seems the return JSON contains an array called "items".  I'm not positive but it seems like each item is a document.  Each item contains an array called "searchHits".  I seems each search hit is an element/part in the document.  The problem I am not able to get around is, when I supply a string to the "rawQuery" part of the request body, I only getting results returned that contain that string in the element/part name.  I am trying to figure out how to get the search to return results from the element/part name and also from the part number.  Does anyone know how to accomplish this?  @caden_armstrong?
    So it seems I may have just messed around and discovered the answer.  in the rawQuery string, I put "_all:" and the search string I want and it seems to compare the string to everything.
