Lofting Along this Curved Path
I have these 2 sketch faces to loft and a composite curve that I'd like to use to guide the outer edge of the loft, but I can't figure out how to make it work. I'm new to OnShape, so I'm not sure if I should be using some other sort of operation instead, maybe? Any ideas?
steve_shubin Member Posts: 1,114 ✭✭✭✭
@Blapor
Here is a GIF of my lofting the document you sent me a link to, without any problem
Below is a modification of your document that allows for a boolean add during the loft if wanted.
As your document was before, it required me to take some extra steps before I was able to do a boolean
https://cad.onshape.com/documents/410212decf85adaad75c613d/w/91dd49ad1432e72b5c178405/e/ce4dcd65cb16f7e99fde04db
2
https://cad.onshape.com/documents/e37f99f504c75ca201b3b9fb/w/de17b0f1f6dc4736ea5c610c/e/14a986e74a67f1595f8ce4ae
Hard to tell exactly what’s happening in your case. If you post the URL or the link to your document, I’m sure there are people that will help you out
But in the meantime, you could take a look at the document above
If you move your cursor over the LOFT in the feature tree, you should see a TEXT POP-UP showing the reason why your loft has failed.
Post what it says, and folks here in the forum will be able to help you.
Thanks for helping.
