Loft tool at a complex object
günter_nimmerfall
Member Posts: 5 EDU
in General
Good evening,
I try to transfer Tutorials for F360 at YT into the modeling process in Onshape. But at a tutorial where lofts are used I can't transfer the lofting steps into Onshape.
The YT tutorial is here
This is the document
Would be great if someone would have a solution.
Kind regards,
Günter
Kind regards,
Günter
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,415That's a pretty awful tutorial - here's one way, not great but ok using match connections https://cad.onshape.com/documents/19938ebb0b95871d24dd13cd/w/e6fb03bea952ed2128f7e6a6/e/f88ec6ba8ce3445276da5e19Senior Director, Technical Services, EMEAI0
thank you for your great solution. I'm happy to see that all features I want to learn are implemented in Onshape.
your solution worked perfect. Thank you! I just have one question:
What's the advantage of the enclose-step?
