Create Array of Vertices from Picked Points
Jonathan_Hutchinson
Member Posts: 149 PRO
What would be the easiest away to return an array of arrays representing picked points?
I am in a bit of a jam as I can only evaluate each vertex obtained from an array parameter pick via a ForEachEntity, which then leaves me stuck as I can't return the evaluated vertex during each round of ForEachEntity to something outside of that loop.
