New to OnShape, need help for a pattern
Hello,
So, I have to make a model like the object below to 3D print.
My problem is that I have no idea how I can make a pattern that cuts with triangular shapes.
Anyone could show me step by step ?
Thank you
  • EvanReeseEvanReese Member, Mentor Posts: 2,443 ✭✭✭✭✭
    edited November 2022 Answer ✓
    Yep. I'm using variables to drive everything, and using equations in the input fields to get the values I want. For example, the total length should be
    #slotGap * (#slotCount + 1) + #slotWidth * #slotCount
    You can just type that into the sketch dimension and it will do the math for you.
    Here's a good way. I went a little over the top in making it adjustable so you can change the number of slots, their width, and the space between them.
  • Diogo_3D_ModelerDiogo_3D_Modeler Member Posts: 4
    Wow! Holy cow, I never thought that OnShape was capable of that ! It seems that there is much more to learn.
    Those seem to be variables, right ?
    Thank you so much for making this file.
