Creating a hex nut using draft function
Here is a video of a technique for creating a hex head bolt and nut in Solidworks.
https://www.youtube.com/watch?v=hXwCE1P02wc
I tried applying this technique in OnShape and I can't get the draft to work. I can create the hex shaped extrusion and sketch a circle on the end face of the extrusion. But the OnShape draft function only allows me to select the side faces of the extrusion which does not provide the desired result.
Help. How do I make a hex nut?
Wynand_Nel Member Posts: 1 ✭
Hope this helps: https://cad.onshape.com/documents/5112a40680d94713a8e1877a/w/59a1448a39934b1980f5957c/e/800700473d974c9ba417b599
The feature tree should give a clear indication of the steps involved in creating the nut. As can be seen from the model, the nut is fully detailed with all the necessary chamfers, internal recesses, etc. since it's a production part that we run on a regular basis. A perfect real world example of the importance of detailed part modeling within Onshape.5
https://forum.onshape.com/discussion/1190/new-video-learn-how-to-make-a-nut#latest
Onshape's features don't have a lot of the useful combined operations yet (like drafting an extrude). To replicate the above exactly you would have to combine the features manually. Extrude the circle as a solid (instead of as a cut), draft the cylinder, and then intersect it with the hex body.
If you share your model as public and post the link I'm sure people will give you a bunch of alternative approaches.
It's hard to improve on the method in the "new video" linked to above, given Onshape's current feature set.
If it was possible to split a solid face, another option would be to apply draft to an outer face, on the end of the nut outboard of the circle which matches the AF dimension of the hex.
This would be vaguely similar to what you tried to do, but there's currently no simple way to split a planar face in Onshape.
It's a bit like trying to translate, word for word, into a foreign language where ideas are expressed in quite different ways.
