Align center of surface with center of group
Hi,
in my assembly, I would like Center1 (which is center of face of Part1) to be coincident (with some offset) with Center of Group1 (Group1 consists of 4 parts which were made by mirroring themselves). Thanks for your help. Martin
Unfortunately the "in between" mate connector doesn't allow picking from different parts in the assembly as @Evan_Reese proposed. Don't forget to vote for it here by the way: https://forum.onshape.com/discussion/9722/assembly-mates-allow-mates-between-multiple-instances
There is a work around if you need it to stay centered as things move in the assembly using linear mate relations as shown here but it takes a bit more work to setup:
https://cad.onshape.com/documents/47c6c3f8282244773d012ab6/w/45c05cff81617055c12ed2f3/e/35595c8a9c42ad7502f40f26?renderMode=0&uiState=6393ab1cb5166a5bef6f8d76
See this thread for discussion: https://forum.onshape.com/discussion/comment/78427#Comment_78427
