ChatGPT/Copilot for FeatureScript?
S1monS1mon Member Posts: 3,460 PRO
edited December 2022 in FeatureScript
I've spent too much time over the past few days playing with ChatGPT. I've tried asking it about simple things in FeatureScript, and it just makes up code which may be more like Javascript - which is disappointing. ChatGPT supposedly doesn't know anything newer than 2021, which is also frustrating.
In any case, it seems like people are having success getting ChatGPT to write certain types of code. It's passed the AP Computer Science written exam. There are plenty of testimonials of it being able to write code that it hasn't seen before. Here's an example of some 3D graphics in three js/HTML. People are starting to get it to successfully do the advent of code exercises. ChatGPT can help debug code too.
I would love to see something like this working for FeatureScript. It's not clear how the large language model was trained on programming, but one would assume that it's scraping things like GitHub and StackOverflow.  Other than this forum, and a few public resources, I wonder what can easily be scraped for training? Are the public FeatureScripts set up in a way that they get indexed by search engines? What can be done to help with training AI models on FeatureScript?
«1
  • Miguel_PiedrahitaMiguel_Piedrahita Member Posts: 2
    I'm having the same experience, it writes code that looks somewhat like FeatureScript at first glance, but it's way wrong. Bummer! (Interestingly, I tested it with OpenSCAD and it does somewhat better.)
    "Are the public FeatureScripts set up in a way that they get indexed by search engines?" This is a good question, perhaps somebody from OnShape can answer?
    When GPT4 comes out, everything will likely get somewhat better, so that may help. Further down the road, hopefully some startup (or OnShape themselves) will build a model on top of GPT with additional tuning and training, resulting in an AI that performs well for this purpose. That would be awesome!
    Looks amazing!!
    I have seen other examples like this creating a module for Odoo (An Open source ERP system)
    I think Onshape could add a FeatureScript repository in their GitHub account https://github.com/onshape-public and add there the "Community sporlight" FeatureScripts
    Even better, users could then add PR to that repository to add new features or improve the existing ones.
    Un saludo,
  • MichaelPascoeMichaelPascoe Member Posts: 2,493 PRO
    This would be great. It doesn't know fs, but you can give it an example and it will auto fill like excel:
  • S1monS1mon Member Posts: 3,460 PRO
    @MichaelPascoe
    Is there some reason you’re using GPT3 instead of ChatGPT?
    I didn't know I wasn't using ChatGPT lol.
    Looks like ChatGPT gets overloaded by too many users, this one seems to work all the time.
    @sebastian_glanzner that could be a game changer in the CAD market
    Un saludo,
  • EvanReeseEvanReese Member, Mentor Posts: 2,516 PRO
    This is a cool use case in the meantime! I bet it could produce some intense tables from a set of references. If you wanted it to take a copy/pasted table for some hardware, and get it to format as a map. I just tested it a bit with this table and prompted it to match this code format:
    NPTChart = {
    "size" : {
    "diameter" : value,
    "tpi" : value,
    etc...
    It seemed to work, but the Playground one didn't write it all (maybe there's a word limit?) and ChatGPT had a network error due to high traffic. What I saw was promising though.
  • jason_1jason_1 Member Posts: 28 PRO
    I had the same idea and tried to use it to generate regex to use for for find and replace to parse AoC inputs in FS. The examples it gave were well explained (and seemed plausible) but didn't actually work. I then asked about doing the same thing in Google Sheets instead and the same thing happened. It's very confident, but often wrong.
    To get it to write longer code, you need to adjust the Maximum length:
    Also, you can chain questions and responses if it didn't quite get it right. Below it's response, tell it the details that it missed and how to do them. Then hit submit again.
  • hugo_gammonhugo_gammon Member Posts: 6 EDU
    If some kind of integration between ChatGPT and Onshape was made it would be a impressive distinguishing factor between this and other CAD programs. There's really interesting stuff to come from this, and I cannot wait for it to be implemented.
    Mainly just commenting to try and draw discussion to this topic.
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    edited January 2023
    https://www.dailymail.co.uk/news/article-11679757/ChatGPT-averaged-C-law-professors-used-generate-answers-law-school-exams.html
    QUOTE — performed particularly poorly at multiple choice questions involving math
    For some reason, i supposed this might be one area it would have been half decent at
    Large language models are apparently not good at math, at least not the way that they have been trained so far. There are a lot of examples at this point of ChatGPT making very stupid mistakes on very simple math problems. It has passed parts of the Bar exam and the AP computer science test free response section.
    Wolfram has a post about combining their tools with ChatGPT which would be pretty amazing.
    GPT4 and plugins for ChatGPT (Wolfram!) have come out since this thread was last active. It's getting more and more amazing...
    I've added an improvement request to create a "Copilot for FeatureScript". Please vote!
    edited March 2023
    Done!
    I have written a series of articles on LinkedIn about ChatGPT and I just published the last one a while ago "I have failed the Turing test again".
    Also some specific about ChatGPT and FeatureScript, like this https://www.linkedin.com/pulse/ejemplo-pr%C3%A1ctico-de-uso-chatgpt-con-featurescript/
    Un saludo,
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 454 PRO
    I use ChatGPT 4 to review my FeatureScripts. It often gives me tipps to use better variable names and makes suggestions.
    Once I asked it to create a FeatureScript itself to build a simple cylinder. The user should be able to input radius and height. The Code had small errors but everything was there. It added inputs, created a sketch and added the extrude. It also added comments!
    Interesting. I just signed up for for ChatGPT Plus, and have just started to play with GPT4. Previously when I tried to use ChatGPT (3.5) and I asked it Featurescript questions, it seemed happy to completely make up syntax which didn't make sense. I don't know what language or API it thought it was talking to, but it was useless.
    Can you share an example of the prompts and dialog you're having with GPT4?
    I tried getting it to help me remember where the "show code" command is (it's in the part studio tab right-click menu). Here are the various almost intelligent but not quite right answers from GPT4 (the Github URL is BS or is no longer real, and it missed the part studio tab menu completely):
    edited March 2023
    @S1mon
    I used german when I talked to it so I translated my prompt:
    Can you help me to program something? I am supposed to create a "FeatureScript" for Onshape. The program should create a cylinder and the user has to enter the radius and the height.
    Of course I can help you with that! FeatureScript is a programming language developed specifically for Onshape. Here is a simple example of a FeatureScript that creates a cylinder where the user can enter radius and height:
    Copy the above code into a new FeatureScript document in Onshape. To use the feature, add it to your Part Studio and enter the desired values for Radius and Height. The cylinder will be created accordingly.
    The I told ChatGPT that I corrected the code, posted it and it replied:
    Great, I'm glad you adapted the code to your needs and it works now. Your version of the code uses a newer version of FeatureScript (1977 instead of 1.0), and you have adjusted the definition of the coordinate systems and extrusion direction accordingly.
    The improved code looks good, and it should now create a cylinder in your Onshape Part Studio based on the user entered values for radius and height. If you have any further questions or need help programming with FeatureScript, don't hesitate to ask.
    When I ask the exact same question it gives me this:
    // Define cylinder parameters (radius and height)
    annotation { "Name" : "Cylinder Radius", "Filter" : EntityType.EDGE, "CustomControl" : "SPINNER_CONTROL" }
        radius is dimension( length );
    annotation { "Name" : "Cylinder Height", "Filter" : EntityType.FACE, "CustomControl" : "SLIDER_CONTROL" }
        height is dimension( length );
    // Define cylinder center point
    center_point = vector(0, 0, 0);
    // Create cylinder
    cylinder = cylinder(center_point, radius, height);
    // Add cylinder to feature list
    opSheetBody(sheetId, id + " Cylinder", cylinder)<span>;</span>
    Maybe I should ask in German :)
    Yeah, it is really weird. You can ask the same question and get different results each time. You can also click on "regenerate response" and you get a "new" answer  :neutral:
    I tried it again and provided a "Template" as a start:
    There are two errors: The plane for the sketch and the opExtrude command is wrong.
  • robert_stilesrobert_stiles Member Posts: 129 PRO
    ha, I just tried GPT (being not very good at feature script). Great I thought, and shared some trial code past with my co founder (who is good at feature script) and he just laughed. I clearly will not be able to stop burdening him with my requests just yet.
    GPT is really interesting, but its obviously all about how much information it has to learn from. Last year I asked it to write a planning design and access statement - I was blown away at how "good" the results were, with relevant, local, and accurate planning policy references. These documents are mostly worthless page fill and box ticking exercises, and GPT is evidently very good at reproducing this. In the UK, all our planning documentation is out there in the public realm.
    I then asked GPT to try and write an outline construction specification for a simple build. It was absolutely laughable. Very few architects share this information, its hard to find even half decent examples out there anywhere. Architects silo this information - its not about protecting IP per say, its just there is no reason to put it in the public domain, nor any repo to put it in.
    I think that's what's so interesting about Onshape in the next 5 - 10 years. Because its all in the cloud, there are so many more examples for AI to learn from, both feature script and model building strategies. Power CAD users have been scripting custom utilities for years, but its always been kept in a silo until now. I appreciate that pro users data might not be shared publicly, but Onshape might still have access to it - if a privacy choice is made? Do we want AI to do get better at this? I do! but is that because I don't do it very well so its not my skills at risk!? To be honest I'm not really sure what my tangible skills actually are, so AI will have to identify these before it takes them from me.
    @robert_stiles
    Availability of training data is huge. Unfortunately if it's not available, it's shocking how much these LLMs will just make up stuff, and still sound confident.
    For all of the Onshape STD source and public Feature Scripts, it would make sense if they were available to some tool to learn from. Internally used stuff would have to only be opt-in.
    edited July 2023
    It's beneficial to inform ChatGPT when it makes a mistake, especially with commands like opextrude. You can do this by simply copying the correct opextrude command syntax from the help documentation (https://cad.onshape.com/FsDoc/library.html) and pasting it into your conversation with ChatGPT. This allows the AI to learn from its error and make the necessary corrections.
    It would be great to have a custom AI that you can train with Onshape data!
    @sebastian_glanzner does it actually add it to its global data or only the data for that conversation?
    @MichaelPascoe
    This will only be relevant for the current conversation with ChatGPT
    @joshtargo You mentioned in another thread that GPT5 is more successful for you these days. I haven't tried it yet myself for FeatureScript. I was wondering if you - or anyone else - would care to comment on the best way to prompt it to help with FeatureScript.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 179 PRO
    @S1mon my cheat code for featurescript vibe coding has been using OpenAI's Codex linked to a github mirror of the Onshape standard library. That way it has full lexical reference for every other feature that exists in the core tools and can compare its output to what's typical. It's not perfect and requires a bit of knowing your way around featurescript in the first place to get the most out of it but it's been an excellent way for me to bash out a lot of fairly complex features in my short time on these forums.
  • joshtargojoshtargo Member Posts: 400 EDU
    it's pretty good as-is, but tbh, you can ask GPT to write you a prompt for this that will increase the changes of it giving you a response that conforms to the standard.
