How do you keep the watermark for a drawing in a released state?
Lukas_Lund
Member Posts: 17 PRO
Currently have multiple end states in our workflow that are for release.
Full release & for quote only.
How do you keep the watermark on the drawings in the released state specifically for the "for quote only" as it would be nice to have that plastered across drawings for sending out to vendors?
Lukas_Lund
I think what I am going to do is add a custom property of a list of the 3 states (Draft, Quote, released) and code into the process automatic updating of the custom property and reference that in the drawings as a manual watermark I lock in the title block .
What is wrong with the pending state?
I see. Out of curiosity, do you have a structuring to your revision labeling that follows the workflow you are describing?
possibly you could create a custom revision scheme. For the first entries of the scheme, you could call them what you like. So for the first step, "DRAFT", the first rev in the scheme would be called "DRAFT". Then as you work through your work flow and continue create more releases(revisions) of the drawing, the rev scheme would automatically be bumped, labeling the drawing correctly. Then when you were ready to release the production rev, the scheme would automatically select "A" and continue forward with more usual revision labeling. if a mistake is made on a drawing and released prematurely, you can use the "make revision releasable" option when manually obsoleting the mistaken release and the corrected release will bump back to the right label. In this way, the state is still allowed to get set to released and an clear indication the drawing is ready to be used for the purpose defined by the revision label is communicated.
I see your point. I would probably do the same thing you have decided on too, if in your shoes. I think notes can be instructed to be pushed to the back of a drawing so that other things are written over top of them, which would be basically a custom watermark. I haven't tested this.
