Export a DXF after extruding
I am using Onshape as a craft maker to cut 1/87 scale building parts.  The laser I use wants a DXF output.  I have figured out how to export DXF files *unless* I have extruded the part.  If I have extruded the part I wind up deleting the extrusion to then delete the 2d DXF.  Is there a way to export a 2d DXF of a part without deleting the extrusion?
  • wayne_sauderwayne_sauder Member, csevp Posts: 605 PRO
    @bill_rutherford
     If you left-click on the face that has the profile you want and then right-click, you should have the option to export a DXF of that face.
