how to make a linear pattern out of a removement?
Hey, I would like to replicate the red marked cutout (Linear austragen 3):
But as soon as I click on the cutout ("Linear austragen 3") it marks the box "elements for pattern" ("Elemente für Muster") red.
Even if I select the direction/s first.
What am I doing wrong?
Thanks!
Thanks!
MichaelPascoe Member Posts: 2,503 PRO
Hi @Voyager, it looks like you have already removed the material with that extrude, then you are trying to remove it again.
Here is one way you can fix this: try changing that extrude remove to Extrude New. Then linear pattern remove the extruded part.
https://cad.onshape.com/documents/4afb3785ab03634aeac67090/w/867e7ee50dd724bf1601b252/e/cdb2ec67b208308745bdd27f?renderMode=0&uiState=63a1dfa48b7fb2245385e5ef
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
