30 degree diamond knurl
S_Regula
Member Posts: 95 PRO
I'm trying to accurately model a 30 degree diamond knurl. The 30 degrees is measured from the vertical axis. I found a way to model knurling using a helix on a cylindrical face and using a remove sweep to "cut" the groove along the helix. But, I don't see a way to define the helix based on a specified angle (30 degrees in this application). Does anyone know of a way to create a helix at a given angle, like I'm trying to do?
TIA!
TIA!
MichaelPascoe
Member Posts: 2,689 PRO
Here is one way you can do this:
Calculate pitch with this equation:
pitch = (π * diameter) / tan(angle)
Example document:
https://cad.onshape.com/documents/ec23266df76b42834bec804f/w/1bd5e08a53511a24e2e59cb5/e/b0a244b76242e358fb8937ed?renderMode=0&uiState=63a1dc4231a9ef1a6663cd6f
Source for equation:
https://study.com/academy/lesson/helix-angle-definition-formula-calculation.html
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
Example document:
