Spline plus cross sections for loft
jacek_zagaja
Member Posts: 47 ✭✭
Possible to draw a spline (middle line of cross sections) and automatically put rectangles (cross sections, Height/2 and Width/2) from file at given length to make a loft?
Length (cm) Area (sq cm) Side Len (cm) Height/2 (cm) Top Len (cm) Width/2 (cm) Width Flare 0,000000 40,000000 0,000000 3,159558 0,000000 3,165000 Uni 5,000000 40,083559 5,000036 3,178329 5,000061 3,152880 Uni 10,000000 40,334567 10,000061 3,204015 10,000154 3,147189 Uni 15,000000 40,755433 15,000082 3,236758 15,000289 3,147859 Uni 20,000000 41,349412 20,000108 3,276690 20,000477 3,154816 Uni 25,000000 42,121674 25,000146 3,323984 25,000731 3,168011 Uni 30,000000 43,078518 30,000204 3,378817 30,001062 3,187397 Uni 35,000000 44,228031 35,000290 3,441393 35,001486 3,212946 Uni 40,000000 45,579783 40,000411 3,511934 40,002017 3,244636 Uni 45,000000 47,145040 45,000574 3,590683 45,002672 3,282456 Uni 50,000000 48,936975 50,000787 3,677910 50,003469 3,326412 Uni 55,000000 50,970398 55,001058 3,773897 55,004428 3,376509 Uni 60,000000 53,262548 60,001394 3,878969 60,005571 3,432778 Uni 65,000000 55,832253 65,001803 3,993451 65,006922 3,495238 Uni 70,000000 58,701426 70,002295 4,117726 70,008509 3,563946 Uni 75,000000 61,893573 75,002876 4,252171 75,010360 3,638940 Uni 80,000000 65,435890 80,003557 4,397226 80,012509 3,720294 Uni 85,000000 69,357543 85,004346 4,553331 85,014993 3,808066 Uni 90,000000 73,691731 90,005254 4,720986 90,017853 3,902349 Uni 95,000000 78,474432 95,006290 4,900703 95,021133 4,003223 Uni 100,000000 83,745876 100,007465 5,093049 100,024885 4,110793 Uni 105,000000 89,550141 105,008791 5,298619 105,029165 4,225164 Uni 110,000000 95,935771 110,010280 5,518049 110,034036 4,346453 Uni 115,000000 102,956530 115,011945 5,752029 115,039569 4,474792 Uni 120,000000 110,670833 120,013799 6,001275 120,045841 4,610305 Uni 125,000000 119,144066 125,015857 6,266583 125,052942 4,753151 Uni 130,000000 128,446466 130,018134 6,548760 130,060967 4,903465 Uni 135,000000 138,657175 135,020647 6,848717 135,070030 5,061429 Uni 140,000000 149,860991 140,023412 7,167374 140,080250 5,227193 Uni 145,000000 162,152882 145,026448 7,505755 145,091767 5,400951 Uni 150,000000 175,635793 150,029774 7,864926 150,104735 5,582881 Uni 155,000000 190,423393 155,033412 8,246034 155,119326 5,773181 Uni 160,000000 206,640630 160,037384 8,650308 160,135736 5,972060 Uni 165,000000 224,423486 165,041712 9,079037 165,154180 6,179716 Uni 170,000000 243,923649 170,046422 9,533642 170,174906 6,396392 Uni 175,000000 265,304267 175,051540 10,015576 175,198185 6,622291 Uni 180,000000 288,747990 180,057096 10,526458 180,224329 6,857672 Uni 185,000000 314,452496 185,063117 11,067963 185,253683 7,102763 Uni 190,000000 342,636287 190,069636 11,641909 190,286637 7,357820 Uni 195,000000 373,540060 195,076688 12,250248 195,323632 7,623112 Uni 200,000000 407,425320 200,084305 12,895024 200,365161 7,898886 Uni 205,000000 444,584170 205,092529 13,578500 205,411787 8,185443 Uni 210,000000 485,332537 210,101396 14,303020 210,464136 8,483043 Uni 215,000000 530,020335 215,110950 15,071135 215,522918 8,791978 Uni 220,000000 579,034301 220,121235 15,885611 220,588944 9,112560 Uni 225,000000 632,794512 225,132299 16,749339 225,663115 9,445067 Uni 230,000000 691,768416 230,144190 17,665498 230,746468 9,789824 Uni 235,000000 756,469348 235,156961 18,637485 235,840170 10,147149 Uni 240,000000 827,459308 240,170667 19,668917 240,945541 10,517347 Uni 245,000000 905,362275 245,185366 20,763746 246,064088 10,900758 Uni 250,000000 990,866209 250,201120 21,926232 251,197523 11,297725 Uni 255,000000 1084,724787 255,217992 23,160914 256,347779 11,708571 Uni 260,000000 1187,773807 260,236049 24,472743 261,517065 12,133640 Uni 265,000000 1300,940648 265,255364 25,867116 266,707905 12,573306 Uni 270,000000 1425,245543 270,276011 27,349829 271,923163 13,027920 Uni 275,000000 1561,817214 275,298068 28,927173 277,166105 13,497838 Uni 280,000000 1711,908692 280,321616 30,606011 282,440464 13,983435 Uni 285,000000 1876,910081 285,346743 32,393822 287,750511 14,485093 Uni 290,000000 2058,365487 290,373540 34,298771 293,101130 15,003201 Uni 295,000000 2257,992424 295,402102 36,329788 298,497915 15,538161 Uni 300,000000 2477,704176 300,432531 38,496660 303,947279 16,090384 Uni 305,000000 2719,635658 305,464933 40,810139 309,456579 16,660294 Uni 310,000000 2986,173453 310,499421 43,282067 315,034268 17,248330 Uni 315,000000 3279,990862 315,536114 45,925513 320,690060 17,854949 Uni 320,000000 3604,089006 320,575141 48,754950 326,435133 18,480631 Uni 325,000000 3961,845296 325,616635 51,786444 332,282362 19,125880 Uni 330,000000 4357,097343 330,660752 55,038055 338,246682 19,791294 Uni 335,000000 4794,156551 335,707646 58,529752 344,345212 20,477434 Uni 340,000000 5277,956385 340,757497 62,284159 350,597866 21,184987 Uni 345,000000 5814,104227 345,810498 66,326637 357,027620 21,914665 Uni 350,000000 6409,091195 350,866878 70,686264 363,661356 22,667386 Uni 355,000000 7070,345408 355,926886 75,395830 370,530134 23,444086 Uni 360,000000 7806,518389 360,990815 80,493091 377,670314 24,245927 Uni 365,000000 8627,768619 366,059022 86,021839 385,124652 25,074355 Uni 370,000000 9546,003998 371,131908 92,032644 392,943209 25,931027 Uni 372,450000 10000,000000 373,611816 95,002850 396,793485 26,315000 Uni
I could image a FeatureScript accomplishing this. I'm not a FeatureScript expert, but see the code and picture below.
FeatureScript 1890; import(path : "onshape/std/geometry.fs", version : "1890.0"); annotation { "Feature Type Name" : "Loft Thing" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type } { const zArr = [0, 10, 20, 30, 40]; const lenArr = [5, 10, 20, 30, 40]; const heightArr = [5, 15, 30, 45, 60]; var qArr = []; var points = []; for (var i in range(0, size(zArr) - 1)) { var sketchId = id + "sketch" + i; var sketch1 = newSketchOnPlane(context, sketchId, { "sketchPlane" : plane(vector(0, 0, zArr[i]) * millimeter, vector(0, 0, 1)) }); skRectangle(sketch1, "rectangle"~toString(i), { "firstCorner" : vector(-lenArr[i]/2*millimeter, -heightArr[i]/2*millimeter), "secondCorner" : vector(lenArr[i]/2*millimeter, heightArr[i]/2*millimeter) }); qArr = append(qArr, qCreatedBy(id + "sketch" + i, EntityType.FACE)); skSolve(sketch1); points = append(points, vector(0, 0, zArr[i]*millimeter)); } opFitSpline(context, id + "spline1", { "points" : points }); opLoft(context, id + "loft1", { "profileSubqueries" : qArr }); });<br>
1 -
That's good however in many cases user need a curve for Z (spline) - planes through the points which are perpendicular to the curve .0
Hi @jacek_zagaja,
@Matt_Shields example will be the best route. Custom features are the way to go!
Alternatively, if you don't want to use custom features, you can feature pattern a sketch while driving the width and height with an array variable. This is a neat technique I learned from @alnis. I modified it by using an array and a counter #i to control the array variable per instance of the pattern. @lougallo fixed it for me by rounding #i so that it is acceptable to the array variable. Variables in the studio are more versatile than most people realize.- Height values can be stored in the #h variable like this: [1,5,3,1,4]
- The counter measures the distance of the square in increments of 1", simulating a counting pattern.
- #i takes the counter distance, removes the units, and rounds. Like this: round(#counter / in)
- #height gets the height from the #h array using the #i counter: #h[#i]
Like this:
https://cad.onshape.com/documents/b62f463d914f8e6f10144c88/w/ce69cdc2a632b488e8292bb1/e/3c2f3fa0766b642add57addf?renderMode=0&uiState=63764ecc9440cb5c2727bc13
RENDERCAD
________________________________________________________________________1 -
Wow. I've done some fun things with patterns before, but it didn't occur to me to use arrays like that. Amazing.
1 -
Michael, thank you very much. Could you please help me making template? Below are height and width ratios. First rectangle is 63x63mm, each line is 5cm further on spline. Total length 372,45cm.
height ratio width ratio 1.0000 1.0000 1.0059 0.9962 1.0141 0.9944 1.0244 0.9946 1.0371 0.9968 1.0520 1.0010 1.0694 1.0071 1.0892 1.0151 1.1115 1.0252 1.1365 1.0371 1.1641 1.0510 1.1944 1.0668 1.2277 1.0846 1.2639 1.1043 1.3033 1.1260 1.3458 1.1497 1.3917 1.1754 1.4411 1.2032 1.4942 1.2330 1.5511 1.2648 1.6119 1.2988 1.6770 1.3350 1.7465 1.3733 1.8205 1.4138 1.8994 1.4567 1.9834 1.5018 2.0727 1.5493 2.1676 1.5992 2.2685 1.6516 2.3756 1.7065 2.4892 1.7639 2.6099 1.8241 2.7378 1.8869 2.8735 1.9525 3.0174 2.0210 3.1699 2.0924 3.3316 2.1667 3.5030 2.2442 3.6847 2.3247 3.8772 2.4086 4.0813 2.4957 4.2976 2.5862 4.5269 2.6803 4.7700 2.7779 5.0278 2.8792 5.3012 2.9842 5.5911 3.0932 5.8988 3.2061 6.2252 3.3230 6.5717 3.4442 6.9397 3.5696 7.3304 3.6994 7.7456 3.8337 8.1869 3.9726 8.6562 4.1162 9.1554 4.2647 9.6868 4.4181 10.2526 4.5766 10.8556 4.7403 11.4984 4.9094 12.1842 5.0838 12.9164 5.2639 13.6988 5.4497 14.5354 5.6414 15.4309 5.8391 16.3904 6.0429 17.4195 6.2532 18.5247 6.4700 19.7129 6.6935 20.9924 6.9241 22.3722 7.1619 23.8628 7.4073 25.4761 7.6606 27.2259 7.9224 29.1283 8.1931 30.0684 8.3144 0 -
@jacek_zagaja, Sure, the easiest way to do this, will be to copy my document I shared with you and use that as a template.
Here are some of the steps you will need to take:- The document is public, so you should be able to click the "Make copy" near the top of the screen when you are viewing the document.
- The next step, will be to edit the #h array variable, and the #w array variable so that they match your ratios in this table. For #h, it would look something like this [1,1.0059, 1.0141, 1.0244]
- Edit the #height and #width so that they are using the ratios and your original desired value. For #height it would look like this ( 63mm*#h[#i] )
- As far as the spline goes, you will need to make sure it has a total length of what you want. There are a few different ways to make a spline, and a few different ways to measure it. If it is a sketch spline, you can use the dimension tool and constrain the length of the spline, I think by clicking the spline itself, or perhaps clicking both ends then the actual spline. If the spline needs to go 3D, you will need to either project two sketch splines together, create a Fit spline with the Fit spline feature, or use a custom feature like Freeform Spline by @Evan_Reese. The spline can be measured afterwards for checking by simply clicking the spline and looking at the bottom right of your screen at the built in measuring tool.
RENDERCAD
________________________________________________________________________0 -
First I'm trying to change cross section from triangle to square and having troubles fixing errors. Problem with Transform2. Also can't find how to modify spacing between planes.
https://cad.onshape.com/documents/f731f72d61c17cddbb926a98/w/7b4c61ca45fb486f06b63c45/e/0a1fd423fa68cb7cc0c2a329?renderMode=0&uiState=637a38d307ac1d328b7388cd
I could make circles to work but now lost the track and I don't know how it works - Transform 2 and Curve Pattern 2.0 -
The spacing was controlled by the spline length from "Sketch - Path". If it has become too confusing, try copying my template again to start over.
Perhaps this custom feature would work better for you, it is still advanced, but not quite as crazy as doing it from scratch in a part studio:
Variable Section Body by @Konstantin_Sh
RENDERCAD
Matt's solution is perfect however spline cannot be manipulated:
https://cad.onshape.com/documents/90116ef313e28f84c8ddd247/w/c3503d19f16862b4aff0d3ea/e/c8c8ad6c4ee2ac90c916c8d3?renderMode=0&uiState=637b8821901f4a490fbc3831
I'd like to make spiral on smaller end and wrap on larger end.0 -
let me know if you are interested in paid job with this0
RENDERCAD
@jacek_zagaja, here is a spin off of @Matt_Shields feature above
Array pattern loft
https://cad.onshape.com/documents/ca7ffb1123545f9575acf9fe/w/1b88800404a3e5f46fa074e6/e/5c7df8ff1761cd9df844fec4?renderMode=0&uiState=63a20aef23e7cc5d03dca262
In case your profiles self intersect, you can manually loft the tail:
RENDERCAD
Michael, thank you so much for taking time on this. Is it possible constrain or measure spline length? Spline length is fixed so that each cross section from array is in right position. Here is edited array version:
https://cad.onshape.com/documents/cf89248aacacae072b6e5610/w/8f1ee5f98585f82bd71300b6/e/9c36d9c7b50705e9ffdc5d41?renderMode=0&uiState=63a2e80758b17b206809b5fe
Happy to help @jacek_zagaja
If you click the spline, you can see its length with the measure icon at the bottom right of the screen. Also, you can measure it with this tool Measure Value by @Konstantin_Sh.
If the spline is a sketch spline you can use the dimension tool directly on it to constrain the length:
RENDERCAD
In your example above you edit 2D spline while we have 3D spline (freeform spline). Maybe better change 3D spline to 2D spline then?0
If 2D works for your needs, then yes.
RENDERCAD
I'll try to convert. It's easier with 2D spline - control points and tangency.0
