How to rotate certain parts in Part studio along different plane?
Hi, I have the following:
As you can see on the image in the right bottom corner, every second iteration of the segment is "flipped". I use Linear pattern to "copy" these segments and then I added transform to rotate the parts on the front axis, making them "go up", but now I need to flip the 2nd and 4th instance (they are separate parts) so they are like on the image.
Thanks for any help!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,947 image
    Mirror first, rotate second, mirror all
  • martin_jagrmartin_jagr Member Posts: 4
    @NeilCooke
     thanks, I already figured it out by the time this post got approved. I used mirror on each segment and then rotating them accordingly.
