How to move constrained point?
in Drawings
I'm creating a ratchet, and need to extend all of the "teeth", each of which are constrained to be equal (shown here by small green line). I want to extend the dimensioned tooth downward as shown by the red circle/arrow. However, I cannot move the point. When I try, it just disconnects the leftward line from the downward line (red arrow).
Here's what happens when I change the dimension:
I'm new here, so any advice on how to properly constrain this thing is welcomed!
Maybe you would find this approach something you would want to use
And because Onshape is a PARAMETRIC CAD program, it makes it easy to modify
Update: Got it with your excellent visual guide -- thank you!
I’m glad to hear the GIF helped !
