Sketch a point at the intersection os a 3D Spline and a Plane.
john_lopez363john_lopez363 Member Posts: 140 ✭✭✭
Is it possible to sketch a Point at the exact intersection of a 3D Spline and a Plane?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    Create a sketch, add a point, use pierce constraint
  • john_lopez363john_lopez363 Member Posts: 140 ✭✭✭
    Thanks Neil.... I totally forgot about the Pierce Constraint. This helps a ton!
