curve fillet help
EvanReese
Member, Mentor Posts: 2,693 PRO
I'm working on a feature that will need to take two co-planar curves as inputs and create a fillet between them (as part of a bigger thing). I'm not sure how to create an arc segment that will hit tangent to the curves. I recall the fillet code that @ilya_baran (and others?) did for 3D Lines, which is a start for me, but I think this code only works for fillets between lines. I also recall @Alex_Kempen making a curve fillet feature, which used construction surfaces and opFillet to bypass the need for doing all of the math, but I'd like to avoid that if I can for performance (it's a good fallback). Is there something more general purpose that would handle curved inputs and behave more like a sketch fillet? Maybe one of the devs can share some more about how the sketch fillet is done?
If they are not both lines, then you would need to generate an offset curve similar to how the lines work here, I left the else code empty because that can be very complicated.
FeatureScript 1930; import(path : "onshape/std/common.fs", version : "1930.0"); annotation { "Feature Type Name" : "Curve Fillet" } export const curveFillet = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Edges", "Filter" : EntityType.EDGE && EdgeTopology.WIRE, "MaxNumberOfPicks" : 2 } definition.edges is Query; annotation { "Name" : "Radius" } isLength(definition.radius, LENGTH_BOUNDS); } { var edges =evaluateQuery(context, definition.edges); var intDist = evDistance(context, { "side0" : edges[0], "side1" : edges[1] }); var edgeBodies =evaluateQuery(context,qUnion([ qOwnerBody(edges[0]),qOwnerBody(edges[1])])); var tls = [undefined,undefined]; tls[0] = evEdgeTangentLine(context, { "edge" : edges[0], "parameter" : intDist.sides[0].parameter }); tls[1] = evEdgeTangentLine(context, { "edge" : edges[1], "parameter" : intDist.sides[1].parameter }); //Make sure they are pointing away from eachother. adjust directions of the lines here so they are at their minimum vector angle apart if(intDist.sides[0].parameter +0.01>=1) tls[0].direction *=-1; if(intDist.sides[1].parameter +0.01>=1) tls[1].direction *=-1; //now to create a true fillet, we need a plane var lineInt =intersection(tls[0], tls[1]); var pln; if(lineInt.dim !=0) { } if(lineInt.dim==0) { pln = plane(lineInt.intersection,cross(tls[0].direction, tls[1].direction)); if(isQueryEmpty(context, qGeometry(edges[0], GeometryType.LINE))==false && isQueryEmpty(context, qGeometry(edges[1], GeometryType.LINE))==false) { //2 lines, easy peasy var plns=[undefined,undefined]; for(var i in [0,1]) { plns[i] = plane(tls[i].origin,pln.normal,tls[i].direction); plns[i].yAxis = yAxis(plns[i]);//store for quick use } //adjust the stored y axis so that the offset goes in the correct direction if(angleBetween(plns[0].yAxis, tls[1].direction)> 90*degree) { plns[0].yAxis *=-1; } if(angleBetween(plns[1].yAxis, tls[0].direction)> 90*degree) { plns[1].yAxis *=-1; } var offLines = [tls[0],tls[1]]; for(var i in [0,1]) { offLines[i].origin = offLines[i].origin + plns[i].yAxis * definition.radius; } var arcCenterInt =intersection(offLines[0], offLines[1]); var sk = newSketchOnPlane(context, id+"arcSketch", { "sketchPlane" : pln }); var trans = worldToPlane3D(pln); var centerToApexDirection =normalize( pln.origin - arcCenterInt.intersection); var arcMid = arcCenterInt.intersection + (centerToApexDirection * definition.radius); var arcSt = project(tls[0],arcCenterInt.intersection); var arcEnd = project(tls[1], arcCenterInt.intersection); arcMid = trans * arcMid; arcSt = trans * arcSt; arcEnd = trans * arcEnd; skArc(sk, "arc", { "start" : vector(arcSt[0], arcSt[1]), "mid" : vector(arcMid[0], arcMid[1]), "end" : vector(arcEnd[0], arcEnd[1]) }); skSolve(sk); opExtractWires(context, id+"extractArc", { "edges" : sketchEntityQuery(id+"arcSketch", EntityType.EDGE, "arc") }); opDeleteBodies(context, id+"cleanup", { "entities" : qCreatedBy(id+"arcSketch", EntityType.BODY) }); var edgeDists = [undefined,undefined]; for(var i in [0,1]) { edgeDists[i] =evDistance(context, { "side0" :qCreatedBy(id+"extractArc", EntityType.EDGE), "side1" : edges[i], "arcLengthParameterization":false }); if(edgeDists[i].distance <0.001*millimeter)//leave some tolerance as distance may return a very small number { edges[i] = makeRobustQuery(context, edges[i]);//probably not needed opSplitEdges(context, id + "trimEdge" + i + "trim", { "edges" : edges[i], "parameters" : [[edgeDists[i].sides[1].parameter]], "arcLengthParameterization":false }); var qBdyEdges = edgeBodies[i]->qOwnedByBody( EntityType.EDGE); qBdyEdges=qUnion(qBdyEdges,qSplitBy(id + "trimEdge" + i + "trim", EntityType.EDGE, false)); qBdyEdges=qUnion(qBdyEdges,qSplitBy(id + "trimEdge" + i + "trim", EntityType.EDGE, true)); var ct =size(evaluateQuery(context, qBdyEdges)); if(ct>1) { var distToInt =evDistance(context, { "side0" :qBdyEdges, "side1" : tls[i].origin }); opExtractWires(context, id + "trimEdge" + i + "extractRemainingEdge", { "edges" : qSubtraction(qBdyEdges, qNthElement(qBdyEdges, distToInt.sides[0].index)) }); } else { println("only : "~ct~"edges found"); } } else { opFitSpline(context, id + "trimEdge" + i + "extendTo", { "points" : [edgeDists[i].sides[0].point,edgeDists[i].sides[1].point] }); } } } else { //need to find a way to offset the edge in the same way as 2 lines. } } });
