Invalid input from opPattern
leti_ryderleti_ryder Member Posts: 7 EDU
Hi guys!
Trying to simply copy a part in the file with no transforms. So I am using opPattern. However, its not working, the software is telling me invalid input.
 var bfsBody = qCreatedBy(sketchId + "revolve1");
        debug(context, bfsBody);
        opPattern(context, id + "pattern1", {
                    "entities" : bfsBody,
                    "transforms" : [scaleUniformly(1)], // note this is an array
                    "instanceNames" : ["scaledBody"],
  • Kirankumar_ThimmegowdaKirankumar_Thimmegowda Member Posts: 28 PRO
    Hi,
    try this,
    opPattern(context, id+"pattern1", {
    "transforms" : [transform(vector(0, 0, 0) * millimeter)],
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    or even simpler:
    "transforms" : [identityTransform()]
    If the input is invalid then maybe change:
    var bfsBody = qCreatedBy(sketchId + "revolve1", EntityType.BODY);
    Not sure sketchId is a good coding pattern - the sketch id and body id should ideally be separated.
