How to set material strength properties in a FS?
John_vd_Werff
Member Posts: 66 PRO
I am using a modified version of this FS to assign custom properties to parts. The FS uses the Material function to set the density for a part (the FS also sets custom properties that are used in the drawing title block)
To use the new Onshape simulation tool I would like to set the material strength properties (Poisson's Ratio, Young's modulus etc.) with this FS too.
The Material function seems to accept only 2 parameters.
Is it possible to set material strength properties in a FS?
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Not as far as I know. Please create an improvement request.Senior Director, Technical Services, EMEA1
