How to cut an object
chad_clevenger
Member Posts: 4 ✭
I'm in need of some help.... I am Designing a part but I need the bottom edge of the extrude to be flat all the way across the part. The line in the picture is where I need it to be cut. imagine the line being a flat surface and I need the part to sit flush I hope this makes sense.
OptionsNath_McC Member Posts: 114 PROCreate a box under it where your line is and then extude. set it to remove thru all. That should do the trick.0
Optionswayne_sauder Member, csevp Posts: 484 PRO@chad_clevenger
@NathanMcC Suggestion is a very good way and maybe the cleanest, but depending on the design intent or if you want to know about different options, you could also try the split tool using a plane, surface, or a mate.0
@wayne_sauder-- I for some reason cannot get it to slice its weird
If you want to make the part shorter, here is an additional way
Give the GIF some time to play through
