Workflow question - parts, assemblies etc.
Hi, I'm a bit confused with how I should structure my parts and assemblies after running into an issue / limitation. I'll start with what I did and the problem I encountered. I am coming from Creo to help you understand my intentions.
I created a part studio and created a "tank", I started to build a frame around this tank in the part studio. I created an assembly and added the contents of the part studio. I added some other components (moving). I went back to the part studio and added some extra parts to the frame. I was expecting the assembly to update but since discovered this is not how it works.
So whats the best approach here? Even if I created the frame in a subassembly, if I wanted to go back and add a section to the frame in the part studio my subassembly isn't going to update. Do I then I have to insert the extra part from the part studio and mate it in the assembly?
Thanks for your time and I hope I made that clear enough.
nick_papageorge_dayjob Member, csevp Posts: 954 PRO
Yes, you insert the new parts from the part studio to the assembly. If it’s drawn in place, you can add it to the existing group in the assy.Think of it this way: your studio may contain 10 parts, but one assembly will use 7 of them, and another assembly will use 6 of them. This allows you the freedom to reuse parts in different assemblies at will.0
If you then add anything to the composite it will show up in the assembly.
It might be helpful to review the the composite part topic if you are not familiar with how they work.
