How to define a point on a sketch plane from a line passing through it.
daddubzdaddubz Member Posts: 5
I need to extrude my sketch at an angle that's parallel to another part.  I thought I would use a sweep to make that happen.  So, I've defined a construction line from that other sketch and I want to define a point where that line passes through my new sketch plane so I can constrain the sketch.  I also made a construction line on the current sketch, but coincident isn't working.  I've included a screenshot.  Thoughts?  Thanks!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,923 image
    Try the Pierce constraint
