Team members can't delete objects in team?
andrew_greenberg693andrew_greenberg693 Member Posts: 4 EDU
Hi folks!
I'm the faculty advisor of a student aerospace team. I created a team under the Educational license, and I invite students to the team. None of the students can delete anything in the team, including objects they create themselves. This is supremely annoying. Is there a setting I missed after hours of searching?
  • Domenico_DiMareDomenico_DiMare Member, Onshape Employees Posts: 87
    Hi @andrew_greenberg693
    It sounds like when you shared the document or folder that your team is working in you didn't give the team Delete permission. You can change this by going back into the Share dialog and editing the teams permission.
    You can learn more about the different permissions and sharing here:https://cad.onshape.com/help/Content/sharedocuments.htm
    I also messaged you if you need more support!
  • andrew_greenberg693andrew_greenberg693 Member Posts: 4 EDU
    Hi Domenico! Thanks so much for the link.
    Unfortunately, it didn't help. If I go to the workspare or folder I want my student team to delete, I click on it, then Share, and then I click the pencil icon to edit the team permisions... and "Delete" is grayed out. I can't check it.
