Navigate Parts inside a Document
Ulises_FM
Member Posts: 74 PRO
Hi!
I have a question regarding the navigation of parts inside a document.
I have been looking for a detailed list of all the parts that are contained within a document, so I can look at their part names, part number or descriptions, for instance.
I have tried to get that from the Workspace Properties tab, but a haven't been able to filter the results to Parts only. Also, If a want to see specific information, I have to expand the list of the Part Studio where the Part was created and left click on the specific Part, which is not very efficient.
Also, I tried the Tab Manager, which has a Search tab and filtering options, but only goes to the Part Studio level.
Through the Insert option inside an Assembly, Parts can be viewed, but detailed information is not shown. It is not very convenient either.
I feel the best tool to do so is the Advanced Search tab outside the document. But I haven't figured a way to filter all the Parts inside a specific document.
Any ideas?
Any ideas?
S1mon
Member Posts: 3,985 PRO
If you have an assembly with all the parts, you can look at the BOM view for that assembly and see names, part numbers, descriptions etc. (assuming you've set up the columns and the parts have those properties defined and filled out).Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1 -
NeilCooke
Moderator, Onshape Employees Posts: 5,970
Custom tables will not work across contexts.javl0p_2 said:I've seen Custom Tables being used to show Part properties of a Part Studio. Is there a way to extend that to every element of the Document?
I've dived into the corresponding FS Code and the command evaluateQuery only applies to a specific Context (the actual Part Studio). I've seen there is a opMergeContexts which could potentially expand the Context to every Part Studio inside the document but I am a bit stuck on how to actually do it.
Anyone?Senior Director, Technical Services, EMEA0
Thanks!
Anyone?
EDIT: Actually, thinking about it you could use Variable Studios and just keep appending to the same variable
chadstoltzfus@premiercb.com
