Cables
billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,129 PRO
edited January 2023 in FeatureScript
I fixed this featurescript last summer and made it public.
I held back making it public because it was buggy. Turns out the errors generating the sweeps weren't being caused by opSweep, but instead, opFitSpline was the culprit. Looking at the curvature combs for the generated spline showed some ugly start/end curvatures which caused the sweep to fail often. Adding 2nd order conditions to opFitSpline cleaned up the spline creation and you could see the problems diminished by looking at the curvature combs.
 I actually used the Cables feature script the other day when needing to know how long a gas pipe was needed for a stove installation.
New curvature combs for the spline created with opFitSpline look really good:
Cables is a simple tool to be used during the design phase to layout cables & harnesses to get a rough understanding where stuff needs to go in a design. In this case I needed to know the  cable length needed to service a stove.
Its listed as a public feature script:
Public feature scripts
It even made my list of popular scripts
    edited January 2023
    This looks pretty useful! Thanks for sharing.
    RENDERCAD
    I use it a lot being more design oriented and leaving details to others. I think there are others out there that'll handle detailed cable harnessing, but they take a lot of time.
