Is it possible to use a variable in a circular pattern?
varun_s_varun_s_ Member Posts: 2 EDU
I have been trying to use a configuration variable to control the number of times the selection is repeated in a circular pattern, but it doesn't accept any variable as an input. Is there a workaround?
  • S1monS1mon Member Posts: 4,068 PRO
    You probably don’t want to use sketch patterns for things like this. A feature pattern is better and can be controlled by a variable.
