Need up with wrapping a feature across the right plane of an cylinder.
im unsure how to wrap these circles around my model to creature rings. ive tried using the wrap feature and creating rectangles and putting them on to the model that way, however i was having an issue with the fillets as i have a cross pattern (grip texture for an ice cream cone) so i wanted to try it like this instead. i used the circular feature to create the vertical lined, but the horizontal lines im unsure how to wrap it.
  • eric_pestyeric_pesty Member Posts: 2,299 PRO
    Can you share a link to your document, or at least post some images of what you are trying to do? It's hard to understand you question without some context...
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    edited January 2023
    @tyler_hughart
    YOU SAID —
    Need help with wrapping a feature across the right plane of an cylinder.
    I’m not sure why you would be having this problem
    Here is a GIF that shows how a circle was wrapped FROM the right side of a cylinder ONTO that right side of that cylinder
  • tyler_hugharttyler_hughart Member Posts: 4
    i added photos when i made the post but i guess they did not post with it. ill add them here.
    @tyler_hughart
    i’ve added a couple more part studios to the document posted above
    BOWL WITH CIRCLE ———
    4 part studios as labeled below
    4 different results
    The below will show you what each part studio ends up with
    They all start out with either a solid or surface bowl shape
    And then a surface tangent plane is applied
    Then a circle is sketched on that plane
    From there they differ
    Here are the end results of each part studio
    OFFSET SURFACE
    Part
    Surface
    INTERSECT SOLID
    2 Parts
    SPLIT FACE
    Surface with 2 faces
    INTERSECT CURVE
    Surface
    Curve
