rotate sketch about a centerline?
Ron_van_Dijk
Member Posts: 16 PRO
I have a sketch that in retrospect was on the wrong plane.
When changing to the proper plane, the sketch was upside down.
So, now I need to flip the sketch about my horizontal centerline, from under the centerline to above the centerline.
Can this be done?
Can this be done?
MichaelPascoe
Member Posts: 2,817 PRO
Hi @Ron_van_Dijk, there are a few ways to do this. The most common would be to create a plane via the Plane feature with line angle, then update the Sketch plane to use that plane. However, this doesn't give you much control over the "origin" of the sketch or the orientation of the plane. I recommend using an implicit mate connector from within your sketch so set the origin and the plane of the sketch.
Tip: Dimension to that implicit mate connector instead of external references. This will allow you to move the sketch wherever you want without breaking dimensions or constraints. To edit the implicit mate connector's position, click the little mate connector icon by the mate connector.
To rotate the implicit mate connector, click the little mate connector button by the mate connector in the Sketch plane input box. Select "Rotate about X".
RENDERCAD
________________________________________________________________________0
RENDERCAD
