Drilling hole on the opposide side
Recently I faced this problem several times asking myself is there any shortcut for that. Hence motivation to write this post.
I draw a sketch of the object to be extruded and the point positioning a future hole.
I extrude the object and then attempt to create a countersink hole directed from the top surface of the object.
At this stage, using the already created point gives me the option to drill the countersink hole from the bottom to the top (from the sketch surface) only.
Is there a simple/quick way how to drill the hole from top surface without creating another sketch with a plane set to the top of the object's surface?
Here is on shape document for example from screenshot above: https://cad.onshape.com/documents/1098f17aa2583b24d99e166d/w/1294ceada4789d58d410b8d6/e/69368c49a561fcc1df036277?renderMode=2&uiState=63d28a1bef705502fc6055bc
thank in advance
thank in advance
1
eric_pesty Member Posts: 2,208 PRO
The only way I can think off is using a mate connector centered on the sketch point. However you may still have to re-orient it as well as add an offset larger than the thickness of the extrude so quite a few clicks still...
It would be nice if it was smart enough to look "the other way" when you flip the direction (and you don't have the "start from sketch plane" option selected)
1
I agree with Eric. If the direction good be flipped it would be a time saver.
