Pattern along a spiral
MichaelPascoe Member Posts: 2,596 PRO
One way to do this is to:
Create the spiral in one sketch, create the circle in another sketch. Use Curve pattern to pattern along the curve setting it to "Feature pattern".
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴5
Axel Kollmenter
I have manually patterned things like this within a sketch. It is possible... but not recommended.
It requires some good constraints and lots of construction lines.
Axel Kollmenter
