CAM in FS
Toshimichi_OdaToshimichi_Oda OS Professional Posts: 53 PRO
Feature Script で CAM を作りました。
I have made CAM in Feature Script.
    fer_fer_fer_fer_ Member Posts: 6 ✭✭
    I wanted to thank you for sharing your FS ncout functionality. In high school I found it very useful.
    If at any time you consider it opportune to improve it, I would suggest a couple of changes.
    The option that you can suppress the header of the G code with a simple Boolean
    ----^O100.nc
    (O100)
    G90 G00 X0 Y0 Z100,000
    The option that you can suppress the end of the G code with a simple Boolean
    M05
    M30
    @fer_fer, Thank you for using a lot.
    Generally, CAM uses a post-processor to output the NC code you want for your the cutting machine.
    Tab 'standardNc.fs' acts as a post-processor in the current version of 'ncout'.
    You can output your favorite code by the following:
    1. Copy document 'ncout' and name it 'My ncout'.
    2. Copy(duplicate) Tab 'standardNc.fs' and name it 'MyNc.fs' in 'My ncout'.
    3. Edit 'MyNc.fs.' For Example:
     Change  (line36):  nc += ["%\n",oName,"G90 G00 X0 Y0",{z:definition.retractZ}];
      To                nc += ["%\n",{z:definition.retractZ}];
    4. Click 'Commit' in 'MyNc.fs'
    5. Edit 'ncout.fs'
      Delete (line4):  import(path : "standardNc.fs", version : "...");
      click 'Import' (left button of 'Commit').
      click 'Feature Studio' in Import dialog.
      click 'MyNc.fs'. Then insert a line 'Import(path : "MyNc.fs", ....)'
      close Import Dialog by clicking 'x'
    6. Click 'Commit' in 'ncout.fs'
    7. Change tab 'sampleA'.
      You can see a line 'G90 G00 X0 Y0' is omitted in FeatureScript notices.
    refer.
    https://cad.onshape.com/documents/4de789cbd2134a0300ee5cfe/w/7fc4e8264cb15a37a173fc47/e/6c153c0aa3871cc23c3e84d3
    I know it is better that 'ncout' will support PostProcessor functions such as 'MyNc.fs' for many machines and switch them easily.
    But I will not release an improved version because only a few people around me  use it and Onshape will release CAM this year as all know.
