Script for extruding a circle section between two points
ricardo_baptista
Member Posts: 5 EDU
Hi I'm looking for where to start for leaning how to write a script that extrudes a simple cilindrical section between two point, for a given (large) point list
Thank you
Thank you
Here's another which will sweep a few different options along a path.
Are you trying to make multiple discrete parts, or a single part which goes from point to point to point....? I think both of these will take curves or edges as inputs and will create one or more parts depending on if the inputs are connected or not.
Best regards
https://cad.onshape.com/documents/eeff86f87f2b3be9ae6915b8/w/c75821c5084576f01fba38b9/e/20afca98c6d27bdccb4b880f
How can I create an array of several x,y,z points, and use them to create several cylinders?
Is it possible to read this array froma file?
Thank you
Best regards
https://cad.onshape.com/documents/2a575063c8b4392a1cbe7a49/w/93079b2e8300196f4e775728/e/ee2303bd27eb61587dc59488
