Can you adjust version description text? Format issue
Ulises_FM
Member Posts: 74 PRO
The Versions and History view of a document is very useful to quickly read the descriptions of its versions. However, this happens (see image).
The description is cut due to the width of the Description column. I couldn't get a way to adjust this width. The best solution would be to simply adjust the text to the width of the column (multiline like).
chadstoltzfus@premiercb.com
