TooTallToby Material new Featurescript
STEGSTEG Member, User Group Leader Posts: 139 PRO
*Texte en français au bas
Hi everyone!
I just created a new version of the FS "TooTallToby Material" where you can see mass in both units (grams and pounds) at once. Now you can change only the length units and skip the mass units change to find the correct mass of your part. You can find it here: https://bit.ly/TTTMaterialBySTEG
All comments are welcome!
Bonjour à tous!
Je viens de créer une nouvelle version du FS "TooTallToby Material" où vous pouvez voir la masse dans les deux unités (grammes et livres) à la fois. Vous pouvez maintenant modifier uniquement les unités de longueur et ignorer le changement d'unités de masse pour trouver la masse correcte de votre pièce. Le FS se trouve ici : https://bit.ly/TTTMaterialBySTEG
Vos commentaires sont les bienvenus!
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,532 PRO
    Nice,
    Just one thought, some TTT parts in IPS are small and require more digits of precision (I think I've seen up to x.xxxx lb?).
    You could be fancy and add a control to input the number of decimals, that would be neat!
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    Nice,
    Missed that. I'll check what can be done! Thanks for the input!
  • MichaelPascoeMichaelPascoe Member Posts: 2,766 PRO
    Nice, thanks!
    Nice,
    I made some testing to find out the values are high precision until they are placed in the table. Since I don't have a lot of experience in FS, I can't find how to increase the precision they have in the table.
    I think the solution is somewhere around here:
    tableRow
    valueWithUnitAndPrecision
    Anyone can help?
    edited February 2023
    Finally found a way to do it by using toString for my values before putting them in the table. Fixed the precision to 4 digits, trailing zero(s) deleted (not by me...  ;) ).
    Will add a new link when I make sure it works properly which is not the case now! lol
