Loft pics up unwanted sketch
john_reed263john_reed263 Member Posts: 11 EDU
I'm trying to loft from the larger circle to a smaller circle but the edge of the cylinder auto-projects onto the plan and the loft tool picks it up.  Is there a way to suppress the projection of the edge of the cylinder onto the sketch plane?  Please see gif
  • _anton_anton Member, Onshape Employees Posts: 510 image
    The sketch has a "Disable imprinting" option. Alternately, you can select both the inner and outer faces of the first sketch into the first loft profile.
  • john_reed263john_reed263 Member Posts: 11 EDU
    Thank you _anton!  Didn't see the "Disable imprinting" option.
