How do I round this edge?
ravindra_wankar
Member Posts: 6 ✭
Hello,
I'm quite new to 3D Cad and have a really basic question. How do I round the edge of this shape to look like the second image? The shape was created using a spline and the rotate tool. I then used the thicken tool to make it thick. I first tried to curve the edge of the spline and then rotate it but I couldn't do that. The spline was created using the Read CSV feature so I couldn't get that into a sketch.
Thank you for your help in advance.
You can access the project here https://cad.onshape.com/documents/34a27c9c83a645d5da0e6b1f/w/08cccdb6cef7f378b40bb455/e/40eb5dd7dd83a065753099f6
MichaelPascoe
Member Posts: 2,803 PRO
@Hans_Leirvik_1 looks like your linked document is private, I wasn't able to access it.
Hi @ravindra_wankar, Welcome to Onshape! Try something like this:- Edit Sketch 1 and constrain your rounded end.
- Edit Revolve 2 so that it has the new geometry.
- Edit Thicken 1 so that it thickens the new surface.
https://cad.onshape.com/documents/d8dd250ca10003265a3be6bc/w/cba15bb7db69daa6bcdf4957/e/cdf2e91338efe0970dcdf8fd?renderMode=0&uiState=63e2504b27961813dc34f575
RENDERCAD
________________________________________________________________________0
Note: When making feature selections, if you select the sketch from the tree instead of individual sketch entities from the graphics area, it will automatically update the feature for future sketch changes. This is the same with surfaces, select the surface from the tree instead so that it will automatically update the feature with future changes.https://cad.onshape.com/documents/d8dd250ca10003265a3be6bc/w/cba15bb7db69daa6bcdf4957/e/cdf2e91338efe0970dcdf8fd?renderMode=0&uiState=63e2504b27961813dc34f575
RENDERCAD
@MichaelPascoe, thanks a lot. I tried that and it works well.
