Extruding beside an edge
I'm fairly new to Onshape, so I'm not sure if I am explaining this correctly. My students are creating puzzle cubes and we are struggling to create certain shapes that require an extrusion that hits the edge of another part of the shape. It only works if we do a "new" extrusion instead of adding onto the existing one, which we don't want. I'm sure this is an easy fix, but I can't seem to find an answer anywhere.
https://cad.onshape.com/documents/e9f0e4292ad89907f19a706e/w/a931088c9dbe258ba586b4f9/e/d6291ad707ace1f9c06d9b55?renderMode=0&uiState=63e3b974b7fb7508c18bbbb0
If you need something approximating this, you can create multiple blocks, use the Move face tool to add a small offset, and then boolean them together.
