Configuration variable issues - scroll wheel increment, renaming?
I have a model with a couple of configuration variables (all reals) and while they have similar orders of magnitude on the Default, Minimum and Maximums, the scroll wheel increment doesn't act the same. With control held down, some increment 0.01 per click, and some increment 0.1 per click. Is this something that comes from the initial range or does it get updated if the range changes?
As a side note, is there a way to change the name of a configured variable? I can easily change the label that goes in the configuration panel, but it seems like I have to delete the featurescript ID to rename the variable once it's configured. Regular variables are so easy to rename, this is really frustrating.
This article is useful, but it doesn't cover these issues, and it hasn't been updated since variable studios came out.
https://forum.onshape.com/discussion/20189/allow-renaming-of-configuration-variables
