Off set not working on all lines
edward_owens
Member Posts: 5 ✭
in Drawings
I am new to Onshape and CAD for that matter. When I click on an individual line the offset works on that particular line only and will not offset other lines in drawing. It will do each line individually but not as a complete drawing. The pop-up says "could not offset entities"
thank you pat
thank you pat
cyclonewade
OS Professional, Mentor, Developers Posts: 53 ✭✭✭
Sounds like you might want to open a support ticket.imagine.create.deliver5
I'll assume when you mention "other lines in a drawing", you are speaking of a sketch. The offset works such that you select each line segment or edge that should be same offset value and then the offset will do the work of trimming the sketch segments. If you want to offset a sketch rectangle, then each segment (4 picks of lines) will need to be selected.
Wade
I agree with you on the non-connected lines being updated, but that's not whats happening here. It allows me to only offset a few lines at a time, it's very random and sometimes it will allow three lines, shut down sketch, then reopen sketch and you can do three of four more lines.
Thank you
When you click and release, you offset a single segment.
However when you click and drag, you offset all connected entities.
see this Tech Tip:
https://www.onshape.com/cad-blog/onshape-sketch-secrets-revealed
