college lesson 2 pdf where is it
Member Posts: 146 ✭✭
college lesson 2 pdf where is it......link?
  • Member, Onshape Employees Posts: 87
    Hi @don_b
    What college lesson are you referring to?
    If you haven't seen, there are a lot of learning resources in our Learning Center here: https://learn.onshape.com/
    I recommend CAD Basics if you haven't used CAD before.
    If you are a teacher looking for curriculum, we have curriculum resources on the Learning Center as well.
  • Member Posts: 146 ✭✭
    I found it .....someone has mounted what I was looking for on github......I will look at your links however your site is so very busy/cluttered with links to paid content that I have not explored it much
    the you tubes are good that you can see the picks....however it is hard to skip forward or trying to find exactly what you want to find.  .....easier in PDF lessons.
    as an example to the difficulties I have.....I do not see this thread and will have to poke around to find it......
