Tech Tip Tip
S1monS1mon Member Posts: 3,920 PRO
@Roy_Mutalik
The latest Tech Tip posted to Youtube is helpful, except it never mentions using Option on a Mac keyboard (my Mac keyboard doesn't have a key labeled "alt", and my Logitech "mac compatible" bluetooth keyboard has the command key also labeled "alt" which doesn't work for this shortcut). It's not super hard to figure out, but it seems weird not to mention, although it is in the associated article.
  • Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 41 image
    @S1mon
    Thank you so much for the feedback/heads up!
    As a matter of fact, you are certainly correct. I use a Mac myself, and my external keyboard labels it correctly as ALT, but I should have mentioned that it explicitly is Option when on a Mac. I will correct this in the article, and add a note to the video!
  • S1monS1mon Member Posts: 3,920 PRO
    I'm also noticing that the keyboard shortcut help has ctrl / ⌘ but does not have alt / ⌥.
