Pack and Go in OS
JoshBarnett
Member Posts: 16 PRO
Hi everyone
Is there a method in OS that allows us to move a parent along with all its children... i.e. pack and go in Solidworks
Asking as I have a cluttered document with 100's of redundant parts... and would save much time if I could filter based on dependency
Thanks
Josh
Thanks
Josh
Machine Designer | AXIS7
Typically if you move an assembly to another document, you can choose to move the dependent tabs into that document too. If you have multiple copies of the same part in a single part studio, Onshape won't be able to just select the instance you need, it will grab the whole part studio tab.
https://www.youtube.com/watch?v=vJ93J1NKfPE
Was this situation created in Onshape, or is it the result of importing from another system? If it's from an import, there may be ways of managing the export/import settings to avoid some of the mess.
Thanks for the link... that method worked great! Would be nice to have a "copy to document" option as well as "move to document"
I have a similar situation (document with lots of 'leftovers' from the development phase), my aproach is:
