How do I disconnect 2 parts in the assembly and how to place a tabletop?
ProApe
Member Posts: 234 ✭✭
Hello,
How can I disconnect 2 parts connected in the assembly?
https://cad.onshape.com/documents/866b71c285a7b3cee8e662ff/w/25d6199479c64b757aa66fa8/e/cccc2cd00a0d614d443a16cb
I had asked the question how I can rotate parts in the assembly; I found that myself.
When I ask a question here, it doesn't appear in the community. Is there a delay or how does it work?
Kind regards
ProApe
How do I place a tabletop not with one corner on the outer corner of a table leg, but so that it protrudes 5 cm all around?
Kind regards
ProApe
Hi @ProApe, the way to do this would be to place the mate connector on your parts when you create them in the part studio. There are tutorials for how to do this with the very best practices here in the Learning Lenter - Learning pathways
For now, you could use an in-context edit to add a mate connector between two of the parts so that you can mate the top to the new mate connector. See the gif below:
https://cad.onshape.com/documents/3292fc621a34cc9f6a464715/w/e462f74b2e4e70429bf5bbe3/e/5da84e99a6cb5018d40748b6?renderMode=0&uiState=63ed0d468f9af21504b1df7d
RENDERCAD
I added strips to the top long struts and one of them is now turned upside down. So I would have to loosen it and turn it, but I haven't figured out how.
It's hard to visualize that, I'm not sure. Definitely check out that learning center though. It has made me much more efficient at Onshape saving tons of time. If you do those tutorials, you will have no problem putting together a table
My forum notifications have been messing up too. I haven't been able to fix mine.
RENDERCAD
You have all the parts in1 Part studio that's good, but it's way better to design the parts in the correct position in that Part studio
Have a look at the learning centre and look at Multi part Studios
Here is an example,
https://cad.onshape.com/documents/cab879beb5915616fb8bc500/w/73ff49efddd89eb8a59a9776/e/04781552f16083d523ba304b
For future reference, when you model something like this table, you generally model the parts where they would be in real life. Rather than any random place. Then, the parts are all in the correct place in the assy. See this example:
https://cad.onshape.com/documents/c55bd9f097a885f069a96d26/v/d17db89ca99ca34cbb3ab7f0/e/e3a29bf28ef3391fefc195ae?renderMode=0&uiState=644200b9e0ee7026498319b4
Besides making the assembly easier, it makes the part studio significantly better. All the parts are interrelated. If you change the size of the top, the legs will move automatically, the aprons and stretchers will automatically become longer, and the 50mm overhang of the top to the legs will remain. Take a look at the first sketch, it is very simple, yet contains the entire basic design.
You can also consolidate steps. For example, you drew a separate mortise, and a separate tenon. If you had the legs drawn in place, you could draw the tenon on the apron and extrude it. Then, use it to "boolean subtract" the mortise from the leg. You can even do an offset within the boolean subtract feature to leave .2mm clearance for glue.
@MichaelPascoe, do you have any tips for an easy way to mate the back and left side aprons and stretchers in my example? I struggle with the best way of doing this also. This is a perfect example: Parts are not mirrored, but rather the same part is used on the left and right side. But no reference features exist to mate it since the part studio was basically modeled "quarter".
Here I took your original design, and added a sketch to the underside of the top in the part studio. Then, inserted that sketch and all the parts into a new assembly studio. Grouped the top and sketch together (before moving them!). Then, mated the top to the origin. Then, mated the corners of the 4 legs to the corners of the sketch. Then, mated the aprons/stretches to the legs. This is probably a better way to approach this assembly, considering you drew the parts in random places. That sketch will insure the leg structure is centered within the top.
Unfortunately, this will break down if you add rounds or chamfers to the legs. But for what you have now with square edges, it will work fine.
