How to make parts rotate together in Assembly?
Timmy
Member Posts: 10 PRO
Hi! I'm new to animating in Onshape. It's probably a silly oversight but I'm trying to make an arm rotate, which works, but the 3 plates that are attached to it should move with it. I've tried putting them in a folder together and grouping them, then add the revolute, but the plates stay in place. How do I make them rotate together?
PS. Sorry for the large image size, apparently images can't be resized here.
MichaelPascoe
Member Posts: 2,785 PRO
To animate, right click the Revolute mate in the panel on the left then select Animate.
In the picture, you are editing the mate not animating, this will only give you an animation preview of the first connected part.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
Sure thing.
