Set default view when changing version.
At the moment Onshape always shows the assembly in iso view. It would be really nice to be able to change the default view when switching between configurations so that you don't need to select the plane each time you change versions. For example; I want to compare Version 1 to Version 2 in the Front Plane, but as it is now each time I switch between the two It goes to ISO view when reloaded.
I suppose you could open them all into different browser tabs and have a version in each, but that seems like a hassle.
1
Flipping back and forth between versions of an assembly would be nicer if it would hold the camera position from one version to the next. Restarting the camera at ISO every time is much less convenient depending on the model, since often I flip back and forth in order to compare the differences between the versions. If it resets each time then the process becomes select version, reorient model, select second version, reorient model in almost identical way, select third version, reorient model again, etc.
I could open up the model in different windows, but I like doing these quick checks on the fly. I'm an industrial designer, and doing rapid changes and checking them out to see how they compare to the previous is a core element of my work flow.
Being able to either have the program hold the current camera position when I jump between models, or pick the default camera position when opening a model would be much preferred.
https://cad.onshape.com/help/Content/compare.htm
[edit]
I re-read the help, and I'm reminded that this only works for part studios, not assemblies. Even better, I already wrote an improvement request to fix this that I had forgotten about.
Vote for it here.
For now, I would strongly agree with the idea of multiple browser tabs. You can quickly get to the views you want with the shortcut keys (Shift 1-7).
Not saying it wouldn't be helpful to keep the view orientation when switching but it's definitely going to be quicker to open your "reference" in second window.
Named views can help too! Especially considering you can add a named view and it will be available in "past" versions.
